VN 5.0L Torque specs
Adamflippa
VQ Statesman
Alright so me and my dad are putting our 5L back together and we have maintanence guide that has ridiculously large tourque specs when comparing to the ones on this forum 117nm-127nm for main bearing caps? Up to 147nm for head studs, I was wondering if anyone can provide their tourque specs would be greatly appriciated. Unfortunatly I cant upload photos as they are too large
Thanks in advance
Utel67
Tasmania
Vs s3 ute
From my book
Head bolts in Nm
Step1 47-55 step2 67-75 step3 90-100
Main bearing cap bolts in Nm
80-95
MikeC
VQ Statesman
And when you've installed the main bearings- Gregory's specify the crankshaft turning torque should be no more than 102 N-m with the heads on, 61 N-m with the heads off.
Personally I'd check this torque before I finished reassembling the engine.
Adamflippa
VQ Statesman
From my book
Head bolts in Nm
80-95
Thanks for this, could you provide a spec sheet if possible with all the torques, if any one had access that would be a great help, as it's time consuming have to cross referencing all of the specs if not thats fine.
Deuce
Super Stock
'94 VR SS V8
Here you go mate.
From 2 different books (I suggest you buy one or two)
MikeC
VQ Statesman
I agree with Deuce. I wouldn't try the job without a Gregory's or other good manual They're cheap second hand and if you do something wrong or leave a bit out you could have wasted your time .
Adamflippa
VQ Statesman
We have max Ellerys manual, but because of those two figures, I am second guessing bits of it good to have something to cross referce
