vn 5l manual in vs v6 wiring problem!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Matts-97vs, Oct 27, 2014.
  1. Matts-97vs
    Matts-97vs New Member
    Western Australia
    97 vs ute
    currently have everything mechanically plumbed up, I'm struggling with the wiring side of it. I have figured out the v8 engine loom wires and am trying to make a patch loom to join the v6 side which is located drivers side firewall (2 plugs, one 6 pin one 8 pin).
    could anyone please help me figure out what these wires do?
    The wire colours are :
    orange
    pink
    green/white
    orange/red
    pink/blue
    red/black
    blue/red
    green
    brown/red
    blue/white
    light green/blue
    green
    brown
    any help would be muchly appreciated
  2. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    Why are you trying to join it to a V6 loom? Which ECU are you running?
  3. Matts-97vs
    Western Australia
    97 vs ute
    I have a 5l manual ecu
    I have the vn engine loom and was told would only need a patch loom to join the two
  4. immortality
    Sth Auck, NZ
    Are you talking about the 2 plugs by the side of the fuse/relay box under the bonnet?
    You'll need to track down wiring diagrams for each model.
  5. VK SL 3800
    VK SL 3800 Well-Known Member
    VK SL 5spd
    A VS SIII V8 S-Pack :
    Yellow Ended Plug at brake booster:
    Red/Black- ECM + all times
    Green/White- Fuel Pump Relay Control +
    Pink- 02 sensor & canister purge solenoid + feed
    Orange- Blank
    Orange/red- EFI Relay Feed + (from pin 30 via fuse)
    Pink/blue- Maf and Auto trans + feed
    Grey Plug at booster:
    Brown Red- To Tachometer
    Brown- A/C + power in from dash and pressure switches to request Compressor
    Thick Dark Green- A/C clutch + feed from Relay
    Thin Dark Green- Temp Gauge
    Blue/Red- Oil light
    Light Green/black- A/C compressor Relay control (earths relay)
    Blue/White- Condenser Fan Relay control (earths relay)
    Battery Harness:
    Purple/white- Start Solenoid +
    Brown- Alternator light
    Under Dash Plug:
    Brown/white- Brake Failure (earthed wire through brake failure light switch if activated)
    Pink/Black- Ignition + Feed
    Purple/white- Speedo signal output
    Blue- Power or economy mode button ( earth or open depends on mode selected)
    White/Black- OBD2 plug,pin 6
    Black/White- blank
    Brown/White- Check engine light Earth side trigger
    Red/Black- OBD2 plug, pin 9
    Blank Hole- Trip computer feed on Engine side of harness.
    I dare say that the Vehicle harness would be the same across both V6 and V8 models but you need work that out for yourself.
  6. Matts-97vs
    Western Australia
    97 vs ute
    Yeah the v8 loom has 2 plugs that end near the fuse box
    but the v6 has 2 plugs in the corner of the drivers side firewall
    so there's a distance of roughly 30mm between the two
  7. Matts-97vs
    Western Australia
    97 vs ute
    350mm sorry
  8. Matts-97vs
    Western Australia
    97 vs ute
    Yeah I'd say they will be the same
    I've nutted out most wires and they match up to what you've said so ill give that a crack. Cheers :)
