304 VN AERO REBUILD (304 stroked to 350ci flat top pistons std 4" bore)
bjf66
Mt Martha Vic 3934
VN HDT Aero
07GTS your using the Johnson lifters for LS
Is the HR lifter part # 2116
bjf66
Mt Martha Vic 3934
VN HDT Aero
I think thats the same as Isky /Johnson 2076HRYT silver priority axle oiling.
They are little pricey compared to your garden variety lifter at 1600+
shane_3800
35
places
vr commo
Are they roller or bush bearing?
07GTS
Australia
VEGTS BUILT BLOWN E85
oiled needle roller bearing
bjf66
Mt Martha Vic 3934
VN HDT Aero
have studied this in last month inside out and upside down
the johnson 2126 priority roller oiling = isky johnson 2076 which is what i purchased
the isky 2078 is the gold with bush bearing and they are $2.5k, which I wasn't feeling that enthusastic about paying
07GTS
Australia
make sure u get the thick pushrods too, i couldnt go bigger so had to go with the .105 wall to make them stronger and i got them with 210 deg ball too
bjf66
Mt Martha Vic 3934
VN HDT Aero
yes looking at the crow 5800=110, 210 degrees that gives me inside hole diamater of 2.3mm, and 0.110" wall thickness
Immortality
Staff member
Sth Auck, NZ
I like Derek@VGG, this might put the cat amongst the pigeons.
(time stamped)
bjf66
Mt Martha Vic 3934
VN HDT Aero
nice video, I set mine on back of cam
I'll check it again this afternoon using this method and then compare notes
