VN Boot leak
BlackVXGTS
Melbourne, SE
Leak is usually from the quarter windows. Easiest way to check is to hop in the boot with a torch. Get someone (that you can trust) to close the boot lid and squirt all around the rear windows and boot with a water hose. You should be able to see where the leak is coming from using the torch. In particular, look at the area near the top of the wheel arches and towards the front of the car.
MikeC
VQ Statesman
Thanks. I'd looked there but I just had a closer look . There's rust visible through a hole in the folded sheet metal that looks like it's come from a water leak in the big VQ rear quarter window. Had the hose out and it looks like it's coming from the bottom of the rubber seal around the outside of the window. I'll try sealing the bottom of the window with windscreen sealant.
rambunctious
Mooloolaba
VZ Wagon
I found a leak in a VN some years ago was the rear screen then running down the rear seat belt hole in the parcel shelf through to the boot.
Fu Manchu
WA.
Slug powered VZ, Cross 8 VZ, VE Calais & ya mum.
A leaking boot was a feature on the VN and VP.
MikeC
VQ Statesman
Yep, and getting worse as they get older. Problem any major rust problem reduces the car to scrap value. I'm sealing the rear quarter glass with windscreen silicon now.
MikeC
VQ Statesman
Finally got the rubber to seal against the window with silicon. Tested it with a hose to make sure. The sun hardened rubber had become so inflexible and hardened with the sun that sealing it was more like puttying a house window than, say, sealing a car windscreen.
VPRob
nowra, NSW
VP executive sedan V6
So Mike, can I clarify that the leak was between the glass and the seal rather than between the seal and the bodywork?
MikeC
VQ Statesman
Sealing the glass to the rubber external seal seems to have stopped it. Heat and age had left maybe a 1mm gap between the glass and seal that trapped water running down the window . If that doesn't work long term I guess I'll have to remove the quarter window and redo its internal seal- but I hate disturbing unnecessarily the plastic and rubber components in these old cars.
MikeC
VQ Statesman
OK. It's been raining heavily and there's still a small leak somewhere in the front of the driver's side of the boot. Out with the hose when it dries out, for a retest.
