VN Calais 5L
Renno
Home Of The Shiny Tank
34
Defected And In The Shed
VN Calais 5L
Model: 1989 Series 1 VN Calais
Colour: Alpine White
Body Work: Smoothed And Deleted Ariel Hole
Engine Type: Holden 304ci V8
Engine Mods: Base Timing Set To 14 Degrees, Deleted Clutch Fan, Replaced With Twin EF Ford Thermo Fans, GHM VR Sender Unit With A Wallbro GSS342 500HP Intank Fuel Pump
Exhaust: HSV "Tuned Length" Headers And Factory GMH 'Y' Piece, Into A Magnaflow 2½ Inch High Flow Cat With A Stainless Steel 3 Inch Mandrel Bent Cat-Back System, Including A 3 Inch Lukey Race Magnum Muffler And A 3 Inch Polished 'Hotdog', Exiting With A 3 Inch Polished Dump Pipe.
Gearbox: Standard Auto
Diff: LSD And 3.9:1 Gears
Power: 133.7RWKW @158KPH On Willall Racing Mainline Dyno (Without CAI And On A Jolting Dyno)
Wheels/Tyres: 15 Inch Chevoits In Alpine White
Suspension: Front Is Standard, But The Rear Has, Nolathane Upper And Lower Trailing Arms / Bushes, Pedders Low Touring Springs, Pedders Upper Spring Seats, GMH Lower Spring Seats, Pedders Big Bore Sports Ryder Shocks, A Whiteline 22mm Heavy Duty Blade Type Adjustable Sway Bar And A Whiteline On-Car Adjustable Panhard Rod
Brakes: Standard
Interior: Standard Leather Trim, Series II VN Calais Ignition Light
Stereo: Pioneer DEH-P6850MP Headunit With Standard Speakers
Other Mods: Full Electric Sunroof, Painted 80L Fuel Tank In 'Quicksilver', With Chrome Straps, VN Executive Boot Release Setup, VP Bonnet Gas Struts And Mounts
Future Mods: Just Cleaning Her Up For Now And Then The Modding Begins
Thanks: AAA Exhausts, AVP Customs, Boss Differentials, Car Torque, Green Welding, Klemzig Platers, Motor Traders, Outlaw Speed Shop And My Good Mates
Pictures:
Exhaust Note:
Renno
34
VN Calais 5L
3 inch exhaust seems a bit of a waste when the cat is 2.5 inch
Good Point Stocky.....
I had a blocked cat so i replaced it with a 2 1/2 inch one....
However later on i decided on a 3inch catback for the cam work im going to do to it later on....
So after a couple of things like suspension, brakes and diff ill be gettin a set of paceys and a twin cat setup so the cat isnt going to waste :)
stocky
you should be able to get the flanges modified to increase them to 3 inches, but i dont know what the internals of the high flows are like. that might work, might not
Renno
34
VN Calais 5L
Good idea but the internal diameter of the cat will semi-restrict the system, so twin cats is the go for the moment....
Renno
34
VN Calais 5L
After looking through the forum and seeing multiple thermo fan installs, I thought I would post up my install. I got my mate Chris (PREDATR) to wire it up to a modified memcal that he had and also we used a VN wagon rear window washer button for an override switch to keep that 'factory' look...
Bz Kn33z
Mildura
Black VN V6 Turbo
Is it just me or is 124RwKw abit low? not insulting you or anything just wondering what the average RwKw for a 5L is.
stocky
why did you use the rear window washer switch? they spring back out once you let go, so wouldnt it be kind of useless unless youre going to hold it down constantly
Renno
34
VN Calais 5L
All Good mate,
124rwkw is low for a 5L, however when i bought the car it was only on 89rwkw to begin with when i bought her, so im happy for now, but this is on a accurate dyno, not a happy one as some people like to go on......lol
Sorry mate forgot to add that i used the a/c button with the window washer cap on it to make it a on and off button.....
