hey guys vn calais V6 Auto. happens random times some times dosent want to change into next gear sits at 4000 to 5000 RPM before finally kickng up gear:bang: holds sometimes for 5 to six seconds sometimes even up to a minute! only started after having tranny serviced before the service never had a problem!!tranny fluids full and kleen HeLp plz:thumbsup:
of course your going to have problems with trannys after you service them, you'll need lots of lubrication to go anywhere.... ohhhh were talking about TRANSMISSIONS...oops check your fluid level, kick down cable and plugs to the transm the T700 still uses eletronic signals from the ECU just not as complex as the VR (ie determines max shift point from RPM limiter) but most of all take it back and say you ****ed it up to the "mechanics"
