Vn clubsport V8 Knock sensor problem.
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by GTS-Replica, Jan 6, 2012.
  1. GTS-Replica
    GTS-Replica Full Members
    Sydney NSW
    Vn clubsport V8 5L knock sensor problem.
    Diognostic test says knock sensor had a look and its blocked off with a bolt. There is a cut red and white wire comes out off left hand lower fire wall traced back to computer dd. Is this wire for knock sensor does any one know what it is. Checked computer and has after market chip i reserched the name on the chip and had no resuts. When you first start it it runs good after 60 seconds engine light comes on and runs ruff. The guy i brought it off said it has a lumpy cam and senator 215i crank It has blue top injectors and cai the car does not sound stock Any help apreciated thanks. :spot on:
  2. GTS-Replica
    Sydney NSW
    The chip say's TVNAM152 anyone know what it means ? cheers Travis.
  3. Krisp
    Krisp New Member
    perth
    D22 St-r Navara
    i will wonder down the back, i have a vp senator ecu , lets see what the code is on that
  4. GTS-Replica
    Sydney NSW
    Thanks mate. The red and white wire comeing throught the computer to the lower left hand fire wall do you know what it is. has been cut off its 1 wire.
  5. Krisp
    Krisp New Member
    perth
    D22 St-r Navara
    nope no idea
  6. GTS-Replica
    Sydney NSW
    Thanks anyway its the chip that plugs into the computer i think its aftermarket cheers.
  7. Krisp
    Krisp New Member
    perth
    D22 St-r Navara
    the red and the white wire on this vp senator loom is for the knock sensor
    GTS-Replica likes this.
  8. GTS-Replica
    Sydney NSW
    Thanks heaps mate is it just the one red and white wire.
  9. Krisp
    Krisp New Member
    perth
    D22 St-r Navara
    yep, goes straight from the plug to the sensor plug
  10. GTS-Replica
    Sydney NSW
    You are a legend mate thanks heaps :)
  11. Krisp
    Krisp New Member
    perth
    D22 St-r Navara
    your just lucky that the motor isnt fully in the car and the wiring is everywhere, no probs buddy
  12. GTS-Replica
    Sydney NSW
    Thanks Krisp :)
