VN column shift gearbox, straight swap with t-bar?
Hallsy02
VN V6 Wagon
G'day,
Gearbox on my VN V6 column shift **** itself, ive found a donor but its a t-bar gearbox.
As i want to keep the column shift, Is it a straight swap with different changer connections/offsets, or is it completely different meaning no use to me at all?
Cheers all.
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
I know on VS's it's not so I'd assume that you'd have the same problem with VN's. The gear shifter output shaft sits on a different position eg: you won't be able to get park and all the gears won't line up.
