Vn commodore transmission leak
Zfmaster
33
Vn commodore
Hey all. Pretty new to the commodore game and just picked up a VN. Starts and drives beautifully but has a transmission leak. Doesnt really piss out but leaks a fair bit and only leaks when its running. I jacked it up and saw a few drops on the two steel transmission cooler lines. Could it be leaking from these two lines? Any help will be appreciated. Cheers all
MikeC
VQ Statesman
Clean the lines and see if you can find the leak. Talcum powder from a puffer will make them more visible. The rubber hoses connected to the steel lines are probably due for replacement- most of my leaks in this are have been due to cracked hoses under the clamps or lose clamps.
Zfmaster
33
Vn commodore
thanks for the reply. I will try get underneath it today and see if the rubber hoses are leaking. I Iooked yesterday and saw the steel lines the join in the trans had oil all over them. Could it be leaking from the join to the trans?
MikeC
VQ Statesman
Yes, that's why you need to clean the pipes and transmission around the pipes to find out where the leak really is.
BlackVXGTS
Melbourne, SE
What does the transmission sump look like - any sign of leaks from the gasket?
MikeC
VQ Statesman
Your new here so I've gotta ask. You are sure the oil on the transmission pipes is transmission fluid? Not engine oil that's sprayed on to the pipes.
Zfmaster
33
Vn commodore
Hey mate. Sorry for the late reply been busy as. Yea 99% sure it is trans fluid as i know its not engine oil and the power steering fluid surely isnt making its way down the transmission. Ive checked the fluid of the trans when cold and its way past the full line and when the cars warm its still over the full line?
MikeC
VQ Statesman
You have to make sure the transmission is not over filled- that causes the fluid to churn, over heat and quickly go brown and smell of burnt caramel. The over heated oil does the transmission no good at all.
Any more findings on the exact point of the leak?
Zfmaster
33
Vn commodore
I was thinking it was probably overfilled. But where is the excess fluid coming from is there like an overflow tube that the oil comes out of? Other than that where else can the fluid be coming from? It is missing the flywheel dust cover but doesnt seem to be coming from there
MikeC
VQ Statesman
Can you clean up the area of the leak and get a photo of where it starts from?
