Vn commodore transmission leak
Zfmaster
33
Vn commodore
MikeC
VQ Statesman
Are you sure the flared unions are tight on the transmission and maybe the power steeringpipes - you may have 2 leak sources.?
  • Like
Reactions: Lex
Zfmaster
33
Vn commodore
Not 100% sure as i cant really get any tool up in there to tighten the unions. And the power steering pipes look all fine but i dont know.
losh1971
North Tas
VE Series I SS Ute
You need a flare nut spanner.
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
https://ibb.co/hKKj31V
https://ibb.co/j6HMwpZ
Here is a photo of it uncleaned and where the oil is and its red which means it either trans of power steering
Looking at the second pic it may well be coming from the front seals in the box, as I had on a VP after a dodgy prick overfilled the box.
It was coming out the front of the box and blowing along the lines.
Mine stopped leaking after it got down to the correct level.
Zfmaster
33
Vn commodore
I was thinking the same thing because when i bought the car and drove it home there was a considerable amount of oil on the floor but even though I checked the oil the other day it is still full so it might be still overfull?
rambunctious
VZ Executive Wagon
FWIW you must check thew oil level either when the car is running and at operating temperature, or straight after turning it off.
MikeC
VQ Statesman
I do it running in park to make sure the torque converter is full, and cycle the transmission through forward /reverse just beforehand.
Zfmaster
33
Vn commodore
Yea i did exactly that. I didnt run it all the way to half way on the temp gauge but the car was warm i cycled drive and reverse a couple times and checked the fluid while the engine was running
MikeC
VQ Statesman
The fluid has to be at normal working temperature 83-93 deg C. The GMH workshop manual says to run a cold car for 24km before checking the fluid level.
