VN compressor bearing
paddyj
42
www.paddyjoy.com
VY Berlina
I'm pretty sure the bearing in my A/C pulley/clutch unit is stuffed.
With A/C on everything sounds good
With A/C off it makes a horrible whining sounds
Is it possible to take the pulley unit off? Should I take this one to the professionals?
Paddy
paddyj
42
www.paddyjoy.com
VY Berlina
Ok got a quote today for $160. This is for, taking off compressor, replacing bearing and re-gassing system.
Is that reasonable? Apparently you need to use a pulling tool to remove the hub so the compressor has to be taken out.
Paddy
308vkcalais
DIO..
Adelaide(City of Godbothers)Churches S.A.
308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
You may find it's not your A/C unit but worn brushes in your Alt.Her Berlina did the same thing & I 2 thought it was the Comp.$2 for sum new brushes shut it up...
