HonoraryPants20
- Jul 12, 2021
- 30
- 5
- 8
- Age
- 20
- Location
- South Australia
- VS Spac series 1, VN Calais series 1
Need some help with my dads V6 VN Calais series 1. The car cranks over but will not actually start. The basic rundown is the car got a brand new exhaust fitted and the next day it wouldn’t start just crank over. It sounded like it had a bad fuel pump and would run on a can of start ya bastard so we replaced the fuel pump with a brand new one which did not make it run again. So far we have checked/replaced about everything to see why it’s not running this includes all 3 coil packs, dfi board, brand new spark plugs, lifted the injectors to see if they are pulsing which they are, fuel regulator, oil pressure switch, all relays and fuses including under the steering column, compression test which it got about 140 psi, brand new crank angle sensor, swapped MAP sensor off another VN, after all this plus more things I can’t think of the car still won’t run any thoughts of what to do?
