1991_Vn2nV
- Mar 9, 2006
- 8,718
- 70
- 0
- Age
- 34
- Location
- Gumeracha, Adelaide Hills
- 91 VN Berlina & 03 VY Berlina
Hey I have the VN SS switch in the centre console next to the A/C switch and I now have the driving lights installed (see attached pic)...
Ok heres the questions. I want the driving lights to come on whenever I press the switch...Therefore a relay is not necessary correct?
If so can I just hook the driving lights up to the wiring for the rear wipers and have the switch plugged into that wiring...(theres no relay for those otherwise I would connect the driving lights to the relay for the rear washers and wipers).... Will the wiring be sufficient for the driving lights or wont it be able to hold enough power?
If I DO need a relay, can somebody please tell me what each of the 5 wires are that are meant to connect to the rear of the driving light switch and which ones I will need to connect?
Also, is a 20amp fuse enough for driving lights?
