VN electrical issue central locking/windows
Peter Rose 264
Auckland NZ
V8 VN calais
so my central locking wasnt working properly i got two accuaters from the wreckers wcih both work fine, 3/4 doors now work fine back driver side accuater wont work but it does work plugged into the other side so i guess its not getting power
After getting the 3 others working i went to put up the windows and blew the ignition fuse so i trying to locate a short in the central locking , windows anad every thing else attached teo that fuse but no luck what am i doing wrong ???
i reko put it in the shop wife says figure it out.
MikeC
VQ Statesman
Check the window motors resistance. Should be about 1 ohm. If it's less than 0.8 ohm you have a short somewhere.
