VN Indicator flashing fast
holdensmychoice
Greensborough
89 VN Berlina 5sp 3.8
Hey guys, I have a small problem... just today when i went out for a drive i noticed my left indicator is flashing fast... so obviously i thought ah yeah 1 of the globes have blown... but i got out and had a look and both front and back indicators are working fine.. flashes normal to the right but the left flashes like its blown 1 but it hasnt. I pulled the fuel pump fuse out under the bonnet when i was doing something and put it back in and i noticed it after that.. i dont know if it was just a coincidence but thought id mention that. Any ideas guys? Cheers - Jay
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Is there an light on the dash for the left indicator?
DJ_Cosmic_Fire
smarter not harder
South East Queensland
www.house-mixes.com
VP S-Pack Oct '91 - VT SrsII Wagon
Clean all the rear wiring loom lugs thoroughly with contact cleaner, check earth & continuity of bulbs & lugs with multimeter then see how you go. It could also be the flasher unit but through experience what I have written here has solved this intermittent issue in the past.
holdensmychoice
Greensborough
Thanks mate will defenitely try that tomorrow and update if it fixes the issue
lumpySS5.7
cairns
2005 vz SS
I have the same problem on my old vn except its the right side. Rear wiring looms are brand new as I replaced them recently due to corrosion. Problem occurred after a blown bulb but persisted after bulb was replaced. Did you ever find a solution?
89vn_Jai
89 VN Exectutive
Usually main causes of this are obviously a blown globe and also incorrect wattage globe or globes fitted!
Rusty
٩(-̮̮̃•̃)۶
Queensland
Vt with VU/VZ bits
Issues with the flasher unit thingo under the dash can cause that. Think it's about $17 and may rectify your issue.
Maybe swap one from a mate's car and see if it fixes it
Sent from my GT-I9300 using Tapatalk 2
