vn instrument cluster
vncommo93
perth
vn executive
Hey all,
I recently bought a level 2 instrument cluster from the wreckers and fit it into my vn. All the gauges work fine but im just wondering if the tacho could be reading incorrectly as when i put my foot down its changing from 1st gear to second at ~4500 rpm? im not sure if the cluster is from a v8 is there any way to tell? and is it unusual to get those reading?
Cheers for any help
Matt
88GreenVN
Next Exit Left
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
The V8 cluster will have green on the tip of temp gauge threads. The tacho will be stamped with V8 on it if you pull the cluster apart.
vncommo93
perth
vn executive
Cheers for the help. What you mean at the tip?
Thanks
88GreenVN
Next Exit Left
Surprise, Arizona
Thanks
On the back side of the cluster where the thread for the temp gauge is (has 2 brass nuts holding it in place) - the tip of the thread is painted green.
Defected
Pakenham, Vic
VF SSV Redline S1 Wagon
vncommo93
perth
vn executive
thanks mate,
it seems to still be running fast in the drags like beating ve sv6's and stuff. the car is completely stock. would it make any difference if i tightened it to rev higher? also could it just be a shotty tacho?
cheers
88GreenVN
Next Exit Left
Surprise, Arizona
The VN tacho is know to be lazy at the best of times. Run a VR/VS tacho in it and it will be heaps smoother.
vncommo93
perth
vn executive
dosn't the vs/vr instrument cluster when put in the vn smoke/catch on fire?
