VN interior and ignition key lights.
Dave6179
NZ
HJ Belmont, VN Calais, VX SS
G'day all. Just relined the roof lining in VN Calais. Now the lights won't turn off automatically as normal.
Didn't touch anything else unrelated to removing the lining, and refitted everything as it was, I'm anal like that!
I've removed the interior light bulb and will take out the key light too.
Any ideas out there?
Cheers!
Deuce
Super Stock
'94 VR SS V8
Isn't that signal all through the door switches? (For door open/closed signal)
Didn't bump anything on removal?
Dave6179
NZ
No, switches well hidden from being hit. I removed all the switches and checked for continuity etc, found some corrosion behind the screw heads, all cleaned but didn't fix it.
BlackVXGTS
Melbourne, SE
Check if any error codes have been set, particularly immobiliser code. Refer to link below for instructions:
