vn lowered, unfoadworthy?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by lachie, Apr 2, 2009.
  1. lachie
    lachie New Member
    Vp commodore 3.8ltr v6
    vn lowered, unroadworthy?
    hey guys, i was talking to my mates old man(who is a mechanic) nd he seems to think that if i put super low king springs on the rear of my car without changing the shocks it will become unroadyworthy. is this true? and if so do i have to change the front ones too if i out sl's on front?
    thanks lachlan.
  2. centy
    centy Member
    Vp series 2
    it will become dangerous which will make it unroadworthy.
    There would be a chance the spring could fall out when going over a bump.
    Also if the car is lowered to far then it become unroadworthy just due to the height.
    Check your local regs, i think qld lists a amount that you are allowed to change it buy and is based factory spec.
  3. padrickz88
    padrickz88 Rick =]
    sunshine, melbourne
    VN V6, nothing special
    super lows should still be over the 100mm but the part that he is talking about is because the spring will not be captured unless you have shortened shockers WHICH like centy said, the spring could pop out.....
    change your front and rear shockers :) stock one's will die in the arse pretty quick on a low car
  4. 94CLUBBY
    94CLUBBY New Member
    wainuiomata new zealand
    1994 HSV CLUBSPORT NO.356
    i put super lows in my vr clubby and they don;t move when the car is jacked up!!only when you put in ultra lows shorter shocks are needed!!
  5. padrickz88
    padrickz88 Rick =]
    sunshine, melbourne
    irs? might be different to live axle?
  6. ScoHar
    ScoHar Jizz in my pants
    CHCH, NZ
    VS Senator
    I've had VR with Live Axle and VP with IRS both with super lows and they both needed shorter shocks.
  7. lachie
    lachie New Member
    hmm i think ill just go the safe option and get shocks too, lol gota bit of saving to do in the meantime anyway, it will be a very slow build as im in year 12 this year and kinda needa concentrate haha, but hopfully will come out with a clean car, cheers
  8. ScoHar
    CHCH, NZ
    VS Senator
    Rear short shockers shouldn't cost you much as they come as a pair, I paid $90 last time I got some, and thats here in NZ where Holden parts are expensive, so should be cheaper than that again, if you want to go really really low you can get RAV4 rear shocks for i.e cut springs (i wouldn't suggest it) but they are really short and same mounting stuff.
    (waits for the crowd to tell me im wrong)
  9. Leebo
    Leebo New Member
    89 VN
    You should have shorter shocks when you put in the lower springs but you don't have to.
    The car will be defective even if it's 100mm or more cos it's considered dangerous.
    I don't think it would be dangerous with super lows just in the rear but if you go ultra low then you will have problems.
    Also how much have you been quoted for shorter rear shocks?
  10. H00LiGaN
    H00LiGaN New Member
    VNSS
    my car vnss went in for a roady and is quite low,i cant even reverse up a set of ramps because the ramps are already hitting the spare wheel well and fuel tank before the ramps are near the back wheels. However when the car was on a hoist both rear springs did fall out and yes i need to use shork shockers, However due to not getting the car up the ramps to replace my hand brake assembly i just had to jack up the passenger rear so i could reach the handbrake and funnily enough with the rear wheel totally off the ground the spring was nowhere near falling out.
    So to me for it to be a serious issue you would have to get both rear wheels totally off the ground before they even think of falling out.
  11. VPCalaisNZ
    VPCalaisNZ Project Calais
    Invercargill nz, ex newcastle AUST
    VP Calais
    I have super super lows in the back of my calais, dropped the back of my car bout 4-5 inches, standard shocks on my car too, when you jack on side up they are solid in there, we have warrents every 6 months in nz, so even if it didnt pass its only a matter of chucking the stock ones in for a day. Im from newy in oz originally, somehow i dont think i would get away with it there, but kiwi cops are a bit slow, and commodores arent your usual copperbait, evo's and wrx's distract the law's eyes from my car.
  12. Leebo
    Leebo New Member
    89 VN
    That's what i was thinking because when i brought the car (with chopped springs in the rear) to get the roady i had to take them out obviously i didn't even have to take off the shock before i could pull the spring out which is dangerous.
    If you jack up the car and the spring is secure (super lows) with standard shocks it should be okay just won't be quite as comfortable.
  13. redcedar
    redcedar workaholic
    coffs harbour
    Alto Grey MY12 SS
    good to see evo's & wrx's are finally useful for something !!!!!!!!!!!!!!!!!!
  14. lachie
    lachie New Member
    leebo i havnt gone in for a full quote yet, i have to save save save but think ill just go safe and oo the whole thing
  15. Leebo
    Leebo New Member
    89 VN
    yeah good idea let me know how much they cost cos i will do mine too.
    thanks mate
  16. bj42turbo
    bj42turbo New Member
    1990 VN Executive
    Just to give you some idea of cost, Lachie.
    I got a quote today at Pedders
    Springs front and rear, Sport rider shocks for the front and Comfort gas in the rear as I still want a reasonable ride
    $920 fitted and wheel aligned.
    Not saying you should go the Pedders but at least it gives you a ball park on price.
    Dazz
  17. Leebo
    Leebo New Member
    89 VN
    Man that's expensive i went in with my mate today who's a mate of the owner and piceked up some brand new shorter shocks (Sport rider) for $118 and adjustable panhard rod $150 and springs about $50.
    I'm so happy with the package, no more crab walking lol.
  18. lachie
    lachie New Member
    `yeh i should get it all done for around 600, mates dads gonan hook me up
  19. bj42turbo
    1990 VN Executive
    Looks like we need to get you to organise it then :thumbsup:
    Did you get Pedders sports rider shocks or Street glyde
    I have been thinking I may just get the package through GSRally off this forum
    Dazz
  20. Leebo
    Leebo New Member
    89 VN
    Ahh yeah spz i got it wrong i meant sports rider (How embarrassing lol.)
    By the time i brought them and mailed them to ya you wouldn't save that much.
