vn manual gearbox to fit vr auto motor?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Wayne 57 Chev, Aug 17, 2008.
  1. Wayne 57 Chev
    Wayne 57 Chev New Member
    vr
    Can someone please tell me if you can put a vn manual gearbox into a vr that is currently an auto? I have been told an auto motor will only take an auto box.
  2. Morton
    Morton For external use only
    Fairstar the Funship
    You're better off chasing a VR box. Do you know what series the VN box is? S1 or S2?
  3. Haydz
    Haydz Fasten your seatbelts
    Liverpool.Sydney,NSW
    VS UTE LS1 T56
    Morton.
    the vn gearbox is the same as a vr.
    only difference will be the flywheel.
    series one has 6 bolts and series two has 8 bolts.
    if it were a vn series one. you would have to change either the crank/engine or get a crank adaptor.
  4. Morton
    Ohhh okay, I was under the impression bellhousings changed at some point. I must be tripping :p NEED MORE SLEEP!
  5. Haydz
    VS UTE LS1 T56
    just the fact that your still up working on your car is crazy. my work stops when it gets cold and dark.
    cant blame you for trying. i wasnt having a shot or anything
