wilso108
- Aug 18, 2013
- 12
- 0
- 0
- Location
- Adelaide
- HX Caprice VK Calais VN V6
okay so I got a VN series 2 engine and rebuilt it and everything in the engine bay. Everything on the engine and in the bay is brand new or remanufactured except for the
Crank shaft
conrods
crank angle sensor
tps sensor and the other sensor on the butterfly..
the two water temp sensors next to each other at the front of the motor
the sensor at the back of the inlet manifold
the MAP or MAT sensor ( not sure what its called ) the one on the firewall above the intake pipe
and the fuel delivery (pump, lines, filter ect)
I did the whole running the engine in thing.. not going over 90-100kph and kept the revs down under 2000 for 1000km.
when I first put the engine in and cranked it, the check engine light came on just thought it was because the light was on with the old engine..
the engine ran perfect no knocks, ticks or anything just a smooth sounding engine
problem was it had a small flat spot when you tryd to accelerate at the start.
I didn't think to much of it and just drive the car ( I had to I had no more time to work on the car...).
but just recently the car goes all weird when I try to drive if I go over 1500- 2000 revs or when under slight load it goes all spluttery really really badly..
the new engine has only done 1480km
found out how to do a error check on the car and I got code 22 and 44 which mean throttle pos sensor below .2 volt for 2 seconds while engine running.
and o2 sensor showed 0.250 volt for over 20 seconds while operating closed loop..
aint got no idea what any of that means and in haste I bought a new tps sensor but not a o2 because I put a new one on with the engine.
could anything else be the problem or does the problem sound like the tps
also is that what might have cause the flat spot when accelerating?
and what would cause code 44?
Crank shaft
conrods
crank angle sensor
