VN runs fine on gas and petrol but only starts on gas
reddevil6
VB Wagon
Hey guys i have a VN dual fuel it runs fine on both gas and petrol (Does sound alot lumpier on petrol) but it will only seem to start on gas then i can switch it to petrol no worries. any ideas? it does have some cams in it ment for gas but i dont know what they are.
Cheap6
VP Exec
Absolutely wrong. With any duel fuel LPG conversion it should start and run exactly the same on petrol as it did before it was converted. The most common faults with petrol fuel systems when on LPG are those of disuse. Blocked fuel filter or partially blocked injectors, dying fuel pump, water (condensation) in the petrol etc.
It's also possible that the petrol only MemCal has been retained. When running on LPG the poor thing will be trying to learn corrections for the air:fuel ratio using the exhaust gas from the LPG mixtures. If the LPG mixtures are not at stoichiometry, sometimes deliberately set so, the petrol mixtures will be wrong when initially run on petrol. It will relearn but that can take a minute or two. You can either drive around on petrol for a few minutes or clear the ECM memory (remove the fusible link closest to the passenger side of the car in front of the fuse box in the engine bay for >10 sec). If the car then starts OK, you've diagnosed the problem; the LPG system should be retuned.
