I'm wanting to remove my s1 manifold and convert to a s2 manifold i have both at the moment and just want to know a definate what has to be done to fit use it? I have searched this topic and did find 'some' info but not a whole lot...
There's a guy selling a custom twin throttle body manifold for like $500 on Ebay. Ready to fit straight into a VN S1. If you r interested in a bit more go
there is less hot water channels under it from looking at the pics immortality has so it might run a little colder and may have minimal flow gains apart from that its the same part
i dont think theirs relay any gain from changing them i looked into it seeing i have the s1 vn now and have all the s2 spares they flow the same but as said they might run a touch cooler not sure
the only hole needed is the PCV valve hole in the drivers side head if you want to use S2 pvc valve setup which is inside the manifold unlike vn s1 setup
fair enough....I thought it was for the water flow....was going to do the samething meself a while back, but figgered, how often do u need to change the thermostat anyway....and while u have the throttle body off u can give it a good clean
http://forums.justcommodores.com.au/vn-vp-holden-commodore-1988-1993/68160-buick-series-1-2-inlet-manifolds.html theres some info here
hey markovr did you only drill the hole in the passenger head cause isnt the pcv hole in the drivers side head at the front LOL
