vn s1 to s2 cooling conversion
Pimpn1
Adelaide, SA
None
hey guys, im looking at converting my s1 vn motor cooling system to a s2, what needs to be changed, and has this been done before?
im thinking it needs
1. new rad
2. overflow bottle
3. inlet manifold from s2
just not sure what else would be needed.
thanks all suggestions considered :)
Zuicider
Banned
Stonedville
Set of thongs
hoses aswell and a different s/steel pipe for the timing cover. thats about it. oh remember if your keeping heads to still use the breather on the rocker covers or u will blow the manifold gasket or even worse the rear main
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
yeah the S2 inlet pcv valve works via a hole in the driverside head on the inlet mating surface it can be drilled easy enough or just adapt the S1 pcv system.
