EYY
- Mar 6, 2011
- 5,754
- 2,036
- 113
- Location
- Vic
- VS Statesman
Yep that’s the group a/gts front setup. They’re a corvette c4 caliper, basically the older version of the newer 330mm hsv brakes except they’re a little smaller. This upgrade doesn’t need a larger master cylinder than stock v8. They are period correct for your vehicle. Not amazing but better than stock. Can fit most 16’s with these brakes. Rear brakes look the same, but use a thicker disc than standard and calipers are wider to suit but still use stock pads.
I sold a set about 18 months ago to a member on here - they’re worth about the same as the 330mm upgrade.
