Vn ss steering wheel removal
Mick G
Vn ss
Hey guys,
Just wondering if there’s a trick to removing the horn pad on a vn ss?
Want to change the ss wheel to a momo.
Any help would be appreciated. Cheers
losh1971
North Tas
VR Ute V6
Got a pic of the wheel?
gtrboyy
vt ss & lc gtr
Look behind wheel to see if any screws to undo...if none like most of vn-vs non airbag cars you peel horn cover off spokes unplug horn earth...then can get to bolt holding steering wheel onto shaft.
vn ss wheel would be like calais 4 spoke I assume.
Can use steering pulley remover(?) or try to break ya nose reefing on steering wheel with no bolt on shaft or leave it on by a few threads & not break ya nose.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
No trick, fingers either side of the horn pad and pull, no screws, it just clips in.
MikeC
VQ Statesman
If it works like a VQ you pull it with your fingers one corner at a time. Don't use anything heavy like a screwdriver- just fingers.
Mick G
Vn ss
Thanks guys, will give it another crack. Tried pulling it off by hand and ripped the top left hand corner of the pad.. that’s why I thought there maybe a trick. Thanks again
gtrboyy
vt ss & lc gtr
If cant get it off will happily remove it for ya then show how good it'll look refitted on my vp ute lol
  • Like
Reactions: Lex
losh1971
North Tas
VR Ute V6
These wheels are hard to find in good condition. Most places ask $400 for a good one. I have a VP SS wheel that I repaired and the horn pad just pulls off. If it's stuck there is something not right. The retaining posts do snap I wonder if yours has been glued on?
Mick G
Vn ss
Cheers guys, I may keep it though. I’m hoping it’s not been glued on...
