Vn SS Wiring
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by RRR, Mar 9, 2007.
  1. RRR
    RRR New Member
    VN SS
    Hi im new to this site, but it looks good so far. I have a vnss that was stolen and burnt!!! the motor and trans were not affected but the wiring was melted where it comes through the fire wall, as the rest of the car is stuffed im going to use the motor in a project car. Do i need a complete loom and computer to get her going, or do you only need the loom that comes from the injectors? Does this go back into the main loom or somewhere else???? ( obviously i need wiring for starter,alter etc etc, but im mainly concerned with the efi part)
  2. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    I think you have 3 engine connectors on the loom that passes the firewall on the drivers side. It has all the dash, door locks, heater controls and audio in it. It also includes most or the relays.
  3. samuels
    samuels Active Member
    VX HSV XU6
    you will need complete loom it's all intergrated to the ECU...all the engine management stuff any rate,like 88 GreenVN said you will need another loom that goes in thru drivers side for all your instrumentation...fuses,etc,etc
