captain stabbin
- Mar 31, 2021
- 20
- 9
- 3
- Age
- 104
- Location
- sydney
- ve calais v v8
do you mean fuel pump relay i have swapped them over still nothing
the engine does not rev justs idle only and the engine is cold and cant get hot because it stalls to soon but i will do what you said some electrical connections that are exposed to the elements will be checked first then the ecu and other connectionsIf the exhaust is blocked it wouldn't rev. and the engine would run hot. These cars are old now and the electrical contacts are not in the best shape- might be a good idea to break every electrical socket you can find that's involved with the engine management system, clean them with contact cleaner then reconnect them making sure they are firmly locked by their locating clips.
Quick story - some years ago I had a fuel injected Peugeot 504. One night at the start of a long trip the car would start and idle but would'n't rev. Turned out that the contacts for the electric fuel pump fuse (below the dash) had oxidised. You've checked the fuse and pulled it out a couple of times?vn v6 auto stalling after about 20 seconds cold start everytime i have replaced the following
fuel pump
fuel filter
iac valve
dfi module
fuel pressure regulator
tps sensor
map sensor
cas sensor
checked and cleaned the earth strap next to battery and the one below the coil pack
the car stalled twice on the highway first time it stalled and waited 5 minutes then it was okay for a few months then on my way to work about 10 mins it stalled at the traffic lights and would not start for about 40 minutes but was running very rough as i was driving to the side of the road so i could get a tow
since then the car will start cold as normal then gradually the rpms will drop then die . no codes have been thrown has anyone have a clue what it might be ? i am about to swap oxgen sensors with my other vn and i have checked trans fluid and engine oil.
