JUS46
ok so i had my tacho wired up all sweet and was workin fine on my vn v6 s1 (i was running the tach signal from the brown wire near p/s strut tower) then i put a s2 coil pack on it and it stoped working ..it still has power and everything jus not gettin tach signal so i took the tacho out and test it on a mates car ..it worked no problems
has anyone else had this problem when they changed from s1 to s2 coil packs?? .....im thinkin maybe the tach signal is a different pin on the dfi module or sumthing
any info on this would be greatly appreciated
thanks
oh and i already tried the tacho wire behind the instrument cluster too
thanks
