VN Temp
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Noy, Feb 2, 2009.
  1. Noy
    Noy New Member
    VN SS 5.0
    Ey guys my ss seems to be getting hot to quickly on idle, I give it a few revs and within minutes shes over the half way mark on the gauge without driving.. I noticed the a/c thermo in front of the radiator isnt turning on when running hot, or isnt it suppost to?
    If not what else could be my problem?
    cheers:thumbsup:
  2. leigh 7005
    leigh 7005 New Member
    adelaide
    vb sle
    it could be your thrmostat
  3. Cheap6
    Cheap6 New Member
    VP Exec
    Maybe look for coolant leaks too. If it's only overheating at idle, the mechanical fan clutch would be a strong suspect.
    88GreenVN likes this.
  4. PaRaDoX
    PaRaDoX Because Racecouch...
    Melbourne, Victoria
    none
    most likely air in the coolant, fyi, water pumps dont pump air well....
    fill it up with water, radiator cap /filler cap off
    start it, cover the radiator cap opening with your hand (before it gets too hot)
    squeaze the top radiator hose and it should help squeaze air out of there, works with my supra, but ive got gremlins in my cooling system hardcore!
  5. Noy
    Noy New Member
    VN SS 5.0
    Thanks guys, I know the clutch fan is working properly so I can rule that out.. im guessing there might be air in the coolant also as my radiator cap is kind of screwed and maybe not holding pressure?
  6. centy
    centy Member
    Vp series 2
    the radiator caps has to hold lots of pressure for the system to work correctly.
    search on bleeding the cololing system.
    I've written it up a few times myself.
  7. wildss
    wildss Member
    s.e melb
    vnss
    yeah try bleeding the system and see how you go.
    i usually just park the car with the front up an incline and run it with the rad cap off till the thermostat opens up and no more bubbles come out from the radiator.
    leave the heater on hot and full fan
    if that fails it will be a sticky thermostat
  8. Cheap6
    Cheap6 New Member
    VP Exec
    If there's air in the coolant there's a leak somewhere; air in = coolant out. The radiator cap would do it.
