vn throttle body
pommycolin
adelaide
vg commodore ute
Hi all.
I have a holden vn that developed fault 22 so i changed out the tps sensor but in tacking off the throttle body
the bloody bolt snapped that holds the throttle cable to the throttle body. I'm now stuck and wondered if it was possible to change the bolt. it is connected to the butterfly that goes to the throttle cable control.
Thanks for any help.
col
Deuce
Super Stock
'94 VR SS V8
Can we have a pic?
Do you mean the end of the throttle cable where it bolts to the bracket? if so, then you will need to replace the cable.
pommycolin
adelaide
vg commodore ute
I have tried to add pics.. I think the part is called the throttle body shaft.
Circlotron
VP Exec 5L BT1 ex cop, ex taxi
Make sure you remove the throttle body off the manifold before you start taking things apart. You REALLY don't want odds and ends falling down inside where only air should go...
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
It's a VN. Go buy a complete throttle body for like 10 bucks. Save dicking around.
hi_ryder
Donating Member
Pascoe Vale South, MEL
theres 50 at pick a part ready to go, and theres no you break you buy clause....
pommycolin
adelaide
vg commodore ute
Ok it looks like i will have to head to the wreckers. I was hoping i could of just changed the bolt. Thanks for your help guys it has been much appreciated.
