JetJackson
- Dec 15, 2012
- 47
- 2
- 0
- Location
- Baxter, VIC
- 1990 VN Exectutive Wagon
I thought I had finished messing with my VN s1 V6, but we all know what thought did. A few days after what I thought was the completion, I found there was still a slight coolant leak and traced it to the gasket between the timing case and block, just behind the water pump - bottom radiator hose.
Damn and blast! Not having done this repair before, but knowing how hard it can be to loosen the harmonic balancer set bolt, I was of cause thrilled to bits at the prospect. A few years back, my local garage replaced the harmonic balancer and told me then how much trouble they had in budging the retaining bolt. With this in mind, I checked through the posts here at JC to see how others managed doing it. I was certainly surprised and a little perturbed at some methods used to loosen the retaining bolt. I thought that none of the methods discussed would be attempted by me. I just can't imagine placing a socket and "tommy" bar on the nut and then (with fuel pump isolated) engaging the starter to attempt loosening. How dangerous and completely stupid this action must be. Anyway, those who have loosened the retaining bolt this way (and not damaged or broken anything), good on them, but there is much safer methods.
Looking at the harmonic balancer and seeing the 3 slots in the centre dish, I thought I could make a "locking bar" to hold the crankshaft still so I could crack the hold of the retaining bolt. I looked through my "stash" of off-cuts of steel bar, RHS (tubes) and sundry scrap and found a piece of bar about 25mm x 10mm and about 360mm long. My idea was to fit this bar with a dowel screwed in place and rest this bar on or against the chassis rail while I swung on a long bar on the end of the "tommy bar" and 24mm 3/4" drive socket.
I drilled a 1/4" hole in the bar and then used a 5/16" Whitworth tap and tapped a thread in the bar (actually did 2 threaded holes), then got 2 5/16 socket cap screws shortened the threaded end with hacksaw and also cut the cap head off. Cap screws or Unbrakos are high tensile (for those who didn't know) and using a cam type stud remover screwed the "dowel" into the bar.
With this tool made, I was ready to have a go at the retaining bolt. I attached the tool to the harmonic balancer and rested the other end on the chassis rail. Next I put my 24mm socket and bar on the bolt head and started leaning into it.
This seemed to work well, but the bar started "skew" so I got a big shifter and put in onto the bar so I could lean against that, stopping the bar from "skewing"
I used extension 'tubes" on both the socket bar and the shifter to give me better leverage and with a bit of muscle (and luck) the retaining bolt started to move. No skin off, no damage, no broken bits.
in this pic you can see leaking coolant on sump flange just near the CAS
With the bolt now loose I used my puller and some long 5/16" cap screws to pull the harmonic balancer. I expected some resistance, but like many of the JC forum posters have said, the balancer on s1 motors will slide without too much effort.
I have read that some guys use a 3 legged puller and pull from behind the harmonic balancer. I absolutely disagree with this method. The harmonic balancer is made up of 2 separate pieces; centre dish, and belt rim and these 2 pieces are vulcanised (bonded with rubber) to absorb vibrations etc, and if pulled from behind the belt rim, the bonding will be destroyed, resulting in having to buy a new harmonic balancer
With the harmonic balancer now loose I can start the next step and remove the timing gear case. I hope I don't get any nasty surprises when I dismantle these parts.
Stay tuned for the next exciting episode!
Cheers, Jet. :beer chug:
