VN V6 Engine Cooling System
Adrian Collins
64
New Zealand
Vn engine fitted in cf Bedford
Hi Commodore brothers. I am trying to put a 3800 V6 out of a VN in my Bedford CF Van and am having difficulty identifying some items. Can anyone tell me what appears to be a water pipe coming out of the front of the manifold as in the picture goes to in the normal application? Cheers
losh1971
North Tas
VE Series I SS Ute
Looks like a fuel line. But there were changes from VN to VR Buick so I could be wrong. The coolant line to the manifold should be closer to the water pump as they have a bypass hose.
Adrian Collins
64
New Zealand
I thought fuel line was just around the manifold that fed the injectors. But emission control system maybe????
losh1971
North Tas
VE Series I SS Ute
Ahhhh OK I thought it must have gone gone to the rail underneath where you can't see. Yeah like I said there was a few changes over the years with very similar engines. I know @gtrboyy had a VP with a V6 he might have a better idea being closer to VN Buick than my bus.
Immortality
Staff member
Sth Auck, NZ
The short hose that does a 90° bend is the PCV valve breather pipe return to the intake manifold. The black steel hard line is the coolant bleed line. On the LS motors they call em steam vent pipes. Basically these lines come from the highest point on the engine and bleed out any air that may be in the system. On an old motor it pays to remove and make sure they aren't blocked for optimum operation.
Adrian Collins
64
New Zealand
The short hose that does a 90° bend is the PCV valve breather pipe return to the intake manifold. The black steel hard line is the coolant bleed line. On the LS motors they call em steam vent pipes. Basically these lines come from the highest point on the engine and bleed out any air that may be in the system. On an old motor it pays to remove and make sure they aren't blocked for optimum operation.[/QUOTE
Adrian Collins
64
New Zealand
Thanks for that all becomes clear. Does the coolant bleed line just vent to atmosphere or should there be some sort of check valve at the end of it? Will certainly take off and clean thanks for heads up.
Immortality
Staff member
Sth Auck, NZ
The coolant vent line goes back to the top of the coolant reservoir tank and it flows continuesly. there is no need for a check valve as the lines are a really small diameter (which is why they are easily blocked). The coolant expansion/reservoir tank needs to be higher than the motor to ensure the system works properly.
Trevor loves holden.
vs commodore
U could of undone it if it smells like oil it be a pvc breather, smells like petrol then its fuel line, if it coolant it will smell like coolant, but you know now, have fun.
