vn v6 extractors/exhuast?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by hagz, May 6, 2009.
  1. hagz
    hagz New Member
    vic/geelong
    vn calais v8
    hey people just wonderin wat reasonable price for vn v6 pacemakers 2 hand and 2 and a 1/2 inch exhuast pretty much new not fitted?????????
  2. Morton
    Morton For external use only
    Fairstar the Funship
    Extractors can be had second hand for between $150 - $300
    2.5" catback:
    redback with two mufflers second hand: $100; brand new: $250
    other random brands with two mufflers: $100; brand new $200
    other random brands with one muffler: $50; brand new $150
  3. Leebo
    Leebo New Member
    89 VN
    I just brought pacies for my VN V6, haven't fitted them yet. is it much of a job like whats required?
    Came off a VR V6 and the O2 sensors different any idea's?
    hagz u may not need a 2.1/2" cat back system you could chop out a muffler
  4. Morton
    The pacies are a bit painful to install, but it's possible. You just have to get the car really high up in the air to slot the bastards in :p
  5. crazybiker
    crazybiker Member
    Sydney NSW
    VR Commodore V6
    Prices? Not sure.
    Doing them though on a VN is quite a pain.
    The steering rack and pinion has to be dropped.
    -=EDIT=-
    Grr. Morton beat me to it >_<
  6. Leebo
    Leebo New Member
    89 VN
    Ahhh i hope your kidding that's a bitch.
    Not just that but the VR O2 sensor has 3 wires the VN's only have 1 and a different fitting where it sits in the exhaust. will these go on?
  7. Morton
    Stick your oxy sensor in.
  8. camstatic
    camstatic I'm back babeh.
    Regional SA
    VZ SS
    You need to extend the wires on your current o2 sensor, or weld a thread into the pass side set of extractors at about just after where the 3 primaries merge, stick your o2 sensor in there, and put a bung in the VR sensor thread which is right down near the cat.
  9. crazybiker
    crazybiker Member
    Sydney NSW
    VR Commodore V6
    1. No. We weren't kidding about it being a pain in the ass.
    2. Stick your O2 sensor in as Morton said.
    3. Extend your wires like camstatic said. It's not that hard to extend a 1-wire O2 sensor :p
  10. hagz
    hagz New Member
    vic/geelong
    vn calais v8
    cheers for that sellin it wasnt sure wat to ask and yeah they a pain to get off so wouldn be any easier puttin em on
  11. crazybiker
    crazybiker Member
    Sydney NSW
    VR Commodore V6
    Everything to do with the drivers side on the VNs are an absolute PAIN...to say the least.
    There is just NO room to do anything on the drivers side of that engine bay. It's ludicrous.
  12. Bz Kn33z
    Bz Kn33z Active Member
    Mildura
    Black VN V6 Turbo
    i got my pacemakers pretty new but used for $150 and a mandrel bent exhaust off ebay $180 and sounds pretty tuff, as said above pacemakers are a pain in the ass to install,
    2bolts for steering rack to be taken down, another bolt for the spline which the whole installation of the pacemakers the hardest bit is the steering rack part, drivers side is a 2 peice, passenger is a one peice and easy to put in, there is enough room to do it on if you have car ramps, also on the VR the exhaust sensor is down further as said, and the wire will need extending but i dont reccomend it, because its reading both sides of the exhaust and plays tricks on the computer my engine light comes off and on all the time because of this, i will be removing the bung on the extractor and putting it there insted so that should solve the problem.
    if you have a mate to help its not as hard, but a VN with pacemakers and 2.5 exhaust with 1 muffler sounds good for what it is. insted of just a 2 1/4 with no resi :p
  13. Fun_Bucket
    Fun_Bucket New Member
    Cairns White Rock
    Cruze II sri
    Or your own brand of exhaust, dumped at the diff, no mufflers, probably 20 bucks:D And with them money you save, hit the wreckers and get yourself some diff gears out of a Pintara:thumbsup:
  14. Leebo
    Leebo New Member
    89 VN
    Thank you guys 4 the help even though this is not my thread lol.
    This may sound dodgy but could u solder the 3 wires in2 my 1 would this work.
    The fitting on the VR is much smaller to a VN 1 or should i just take it to a small workshop and have them do all the stuffing around how much do u think they would charge?
  15. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    i am pretty sure the O2 sensors are the same size where they bolt up, just have more wires use your o2 sensor not the vr one, if it wont bolt up get an exhaust place to fix it up for stuff all.
  16. Leebo
    Leebo New Member
    89 VN
    Yeah they may have to cut it out and put in a bigger thread 4 a VN O2 sensor.
    I never thought it would be this much work when i brought them damm it!!
  17. crazybiker
    crazybiker Member
    Sydney NSW
    VR Commodore V6
    Curios to know...why DID you buy VR extractors?
  18. Leebo
    Leebo New Member
    89 VN
    The guy said they would fit mate i didn't know. I had some more conversation with some guys i work with and they said they probably wont fit the Y piece.
  19. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    i got vr pacemakers aswell, and they are fine, also has the manual Y pipe and i had an auto and no rattles or anything, its really not that big of a deal the exhaust place will fix it up in no time take it into them if they are not on the car and get them to do it and it will be cheap as piss, VN to VR are the same unless its S2 VN competion pacemakers they are bigger and they dont fit on a S1 VN what is the part number on the pacemakers?
  20. ucwepn
    ucwepn America just kicked in yo
    WH statesman 5.7
    when i had my starter done the left extractor had to come off and the steering rack vn's are not packaged very well imho, sorry to veer off the subject slightly. mort prices spot on
