vn v6 flywheel verse v8
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Zuicider, Oct 13, 2008.
  1. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    will a v8 vn flywheel fit and work on a vn v6 6 bolt pattern crank?
    just curious if anyone knows cos v8 billets are cheap compared to v8 ones. my mate did a conversion of a v6 series one into his hilux and was chacing a v8 flywheel to chuck in. would it have worked?
  2. PaRaDoX
    PaRaDoX Because Racecouch...
    Melbourne, Victoria
    none
    as far as i know the input shaft is diffrent, and the bolt pattern isnt the same either, sure the converter may be the same...
    plus arnt the v8's a 8 bolt? the LN4 was a 6 bolter however the EV6 was a 8 bolter, as the V8 isnt a buick motor, its a aussie donk i doubt the bolt holes are the same...
    maybe someone else can give more insight
  3. 383 hatch
    383 hatch Well-Known Member
    Cowes, Phillip Island
    V8 flywheel will not fit any v6. The flywheel is a lot bigger and completely different bolt pattern.
    Paradox: For the record the 5 litre has a 6 bolt flange.
  4. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    cheers fellas
