Vn v6 harness problem
vnwagz91
24
singleton
vn 3.8 wagon
Having trouble finding the right engine harness for my vn have had a s1 and s2 harness but both don't match plugs at the fuse box or inside the car
gtrboyy
vt ss & lc gtr
Actual plugs don't fit each other or wires in different configuration?
Even later vs v8 physically plugs into vn/p harness just need to re-pin plugs with small thin flat blade screwdriver into front tab & gently slide wire out back.
Also some harness will have extra pins on one side & not the other for either higher spec models or just stuff particular car doesn't have...only main difference I can remember is S1 have orange/red trace wire instead of red/black trace wire that was more common.
Trace the wires & match up were they go to be sure anyway.
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Those two looms you show look like the passenger side looms to me.
