- Apr 15, 2006
- 22,613
- 20,488
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
The major difference between the s1 and s2 manifolds are the location of thermostat and the PCV system. Things like exhaust manifold and TB's are identical. Your turbo kit should bolt up fine. You will need to modify the PCV system so that you don't pressurise the sump when the engine is under boost.
I do recommend that you upgrade to the ecotec oil pressure valve relief spring as they run more oil pressure that the Buick 3800 engines, the s1 was the worst with only about 40psi oil pressure.
