greenfoam
- Jan 13, 2005
- 7,902
- 128
- 0
- Age
- 102
- VP Executive R-spec
I don't need anywhere near 300kw, I've done my sums on engine analyser and drag race pro and there is monster torque, more than enough to get a 1350kg car there in less than 14 seconds. With a single non intercooled T4 and 8 pounds of boost a totally stock V6 in a VN will run between 13 flat and 13.8 depending on the tires, because it wont be able to run at more than half throttle in the first two gears, I'll need to run premium or 98 octane fuel and have less spark timing when things are getting heavy (12 degrees in the mid range of the spark map) but yeah that's how it adds up. Just have to find a cheap turbo and I think a different map sensor that outputs the same voltage range as the stock one or at least make it output the same, I'm not sure about the map sensor yet and I have to find out how much fuel the stock injectors can supply because that might be borderline at maximum revs. About 10 years ago my friend had a LJ torana had a home made single turbo fed by two carbys on a 350 chev, he spent less than a grand on his and it made monster power, he had to run slicks on it driving aroung the street to stay on the road and it could still smoke the tires anytime you wanted at any legal speed, it left an impression on me.
Slooth I know it seems the stock motor wont handle the power but really it should, it's only a small amount of boost and it's not going to be doing many revs so there's not alot of stress on the engine and they are strong engines to start with, It's not worth much extra power to run an intercooler in this case and it adds alot of price so I'm not doing that. So all that's needed to buy is the turbo a waste gate and a boost gage really, I"ll make eveything else and I'll have to buy an 02 sensor to get the fuel injection sorted (but that's a tool and doesn't count: ) ). I will need a better exhaust but that doesn't count in my $1000. Anyway my car's stock now and still runs 8.2 seconds 0-100 with a full tank of fuel and my normal 20-30kg of cargo in the car, with a turbo that will close to 5 seconds flat, that would be much more exciting
