Got some more wiring done yesterday!
I have been focusing on the radiator fan mounting and getting the wiring as neat as possible while also being able to remove the fans with ease. There are two sets of spade connectors setup up under the electrical tape that can be undone so the fans and radiator itself can be removed. The previous setup was a real headf%ck as the fans were hard wired into the loom and had to stay in the engine bay when the radiator was removed.
One of the fans motors supplied in my turbo kit had been tight ever since the car was first run in, I went out and ordered another one to replace it as i don't want it completely failing under boost.
Also finished up the fuse box earths and re-installed the aerial setup to the passenger sill panel.
The windscreen wiper motor and washer bottle have both had their wiring routed but I still need to connect them up under the dash. Note the washer bottle wiring has a fair bit of length on it so it can be hidden behind the brake booster.
I'm getting there slowly..
