VN V8 5.0 litre Rebuild
Discussion in 'V8 Development and Modification' started by jwk87, Aug 5, 2006.
  1. jwk87
    jwk87 FJ Holden nut
    North Essendon, Victoria
    FJ Holden's, VE Commodore & an Astra
    Hi all,
    Im about to pull out a V8 auto out of a VN wagon. I know the bearings are stuffed and the car will turn over but will not start.
    I am going to rebuild this motor and it will go into my FJ panelvan.
    What items should I replace while I am rebuilding this motor. What major problems do we have with the VN 5.0 litre.
    Any suggestions would be great.
    Jason
  2. geardys
    geardys GEARDY
    Tasmania
    95 v8 ute 5sp
    Everything
    If I was to rebuild my motor I’d replace all the bearing, new pistons and rings (30 thou over) get the entire bottom end fully balanced and the heads planned, with a really top valve seat job.
    Plus make all the run outs/ins as close to each other as possible.
    Also add a different cam, maybe a hyd roller cam and heavy valve springs.
    Get the block cleaned, decked and tested for cracks.
    It might cost a bit more but the engine would last longer and produce more power.
    Cheers and good luck
