Simba355
Hi all.
Trying to source the reason why I don't have injector pulse now.
Upgraded to a walbro fuel pump and started the car to test it.fuel pump worked perfect but had noticed it was running on 7.I had noticed one injector plug was failing to make a conection and had an exposed wire and it earthed out.soon after it died.
Has fuel pressure
Has spark at the plugs
Put 4 old injectors in one bank and no fuel spray
If I disconnect all the Injectors and check the volts at the injector plugs it reads 12v on one and 10.8 on the other .if I connect the Injectors back up I get 12v on one side and 0v on the other.
I'm wondering if the ECU has cooked itself after the injector plug earthedout on the manifold.?
Has fuel pressure
