EYY
- Mar 6, 2011
- 5,754
- 2,036
- 113
- Location
- Vic
- VS Statesman
Sure they have options - even crane cams don’t get that great a wrap for the 304’s in reality. Camtech, Kelford, Wade and Clive cams were the companies to go to for 304 grinds.How much r and d do you think was done specifically for the 304? You don't think maybe they found some things that worked , why they worked and did other things similar to fill the gap?
With durations similar to each other you've only got timing and lift to worry about. The new love profiles by lunati have more lift than the old crow and crane.
They also have reverse and standard split. Reverse to help the tpi style banana intake manifold cheat the low compression and out of breath.
Or the other direction because cold air flows easier than hot air and the VN exhaust ports don't work as well as intake.
They even do straight symmetrical grinds.
Almost every single camshaft if you look at the timing cards for a Holden is based on SBC opening and closing and just with some duration difference in the middle no-how.
Anybody could just pluck specs of the internet and alter durations slightly and add a little bit of lift and be confident that it’ll work. They’re a dinosaur engine, and aren’t that fussy for the most part.
I’m not putting down their cams at all, they may have invested plenty of money, purchased plenty of Aussie vehicles and run each of their cams in hundreds of 304’s.
Just saying I’d tend to stick with a company that’s renowned for their 304 cams here in Aus. And if we don’t support Australian manufacturing now, it’ll be gone forever.
