VN Wagon towbar fitting
thespirit
st. mary's tasmania
VN Commodore wagon
g'day,
can anyone give me any idaea about whethet i have to drop the petrol tank to fit VN wagon towbar
thanks the spirit
hakhawk
smooth moderator
Staff member
mm, when i took mine off, i only had to drop one of the straps. drivers side one from memory, as it used a bolt in same spot as strap bolt
SweetWagon
booosted
33
Springwood NSW
VS Berlina Wagon Supercharged
Your in luck, I have recently fitted a towbar to my wagon, if your towbar looks like the one in the attachment then heres how to do it.
You have to remove the rear drivers side, fuel tank strap bolt, making sure you remove the spacer. This is becase the towbar mounts on this bolt location and you will not need the spacer anymore as the plate will substitute this now. then you have to centrepunch all 5 holes (2 drivers side, 3 passenger) so you can see where to drill on the inside for the bolts (The holes need to be a large as the diameter of the spacers). Once all 5 holes are drilled, lift the towbar up with a mate and from the inside feed the bolt through the mounting plate and make sure you use the spacer which goes in-between the mounting plate and the chassis rail and do the nut up from underneath.
If you have any probs or need pics let me know
SweetWagon
booosted
33
Springwood NSW
The attachment didnt work, try this one
bobmat111
Adelaide. South Australia.
Commodore 1988 VN Calais S1 V6
I had a Vn Wagon a few years ago and going by the picture that you added
It looks very much like the one that I fitted to my wagon.
I would say you have the right one, good luck.
cheers.
Bob...
bobmat111.
