vn water woes
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by VTPREDATOR, Feb 1, 2009.
  1. VTPREDATOR
    VTPREDATOR New Member
    Warwick
    VE SS SPORTSWAGON
    just recently pulled heads off a vn v6 thinkin it had done a headgasket(water in oil). replaced all gaskets including the inlet manifold. but it is still getting water in the oil. when i undo the right hand rear headbolt, water pours out of the bolt hole. is that supposed to happen? any ideas on what could have gone wrong. its a pain in the ass. :bang::bang:
  2. centy
    centy Member
    Vp series 2
    timing case seal maybe.
  3. immortality
    Sth Auck, NZ
    some of the headbolts go into the water jacket. i too would be looking at the timing cover. was there any corrosion on the intake manifold?
  4. VTPREDATOR
    Warwick
    VE SS SPORTSWAGON
    in the usual spots around water ports,
  5. centy
    centy Member
    Vp series 2
    if the corrosin has eaten away inside somewere you will have a hell of a time finding it.
    i would do the timing case and then flush the sytem and then use a leak sealer coolant to see if the problem goes away.
