Voot Voot noise & Vibration when doing 100kph
Stoker
VX Executive S2
Hi, I have a VX Commodore Series 2 2002 and when I'm doing 100kph I get a voot voot noise coming from the front. There is also a slight vibration every time it makes that noise. When doing that speed and going around a left hand bend the noise goes away, but then when it straightens up noise comes back again, then when going around right hand bend noise does not go away. I have put in new lowered spings, shocks, radius rods & bushes, control arm bushes and I changed the left front wheel bearing hub and the noise is still there. any ideas on what it could be?? Should I possibly change the right Front Bearing hub as well??
kizza_VL
vx s pac
G'day mate, i have a vx commodore too, and i had a vibration and stuff at 105ks + and i took it too holden and it ended up being that my crossmember had moved a tiny bit.
Stoker
VX Executive S2
Thanks for the reply, So did the crossmember need to be replaced?
pablo
Donating member
Was a 1997 vt v6 wagon
Check that one (or both) of your engine mounts have not sagged, causing the sump to vibrate against the cross member!
kizza_VL
vx s pac
sorry for the late reply. But no it didn't need replacing. They just losened it off and straightened it up.
6-PAC-ATTACK
41
VT EX S1 3.8L
Check for grease spray around your cv joints could be them
