VP 3.8 Series II Buick swap for VY L67 - Engine weights
Gemadore
TG Gemini 3.8
Im swapping my Series 2 Buick for a Supercharged VY ecotech (L67). Does anyone know how much the Buick engine weighs? (I know the L67 is 178kg). I want to make sure the ride height will be the same etc. Thx.
Decicrate
BrisVagus
VS L67
Hope this helps.
Straight from Wikipedia
Series II
Introduced in 1995, the Series II is quite a different engine. Although the stroke for the 3.8 L engine remained at 3.4 in (86 mm), and the bore remained at 3.8 in (97 mm), the engine architecture was vastly changed. The deck height is shorter than the Series I, reducing weight and total engine package size. This required that the piston connecting rods be shortened 1 in (25 mm), and the crankshaft was also redesigned. A new intake manifold improved breathing while a redesigned cylinder head featured larger valves and a higher compression ratio. The result was 205 hp (153 kW) and 230 lb·ft (312 N·m), better fuel economy, and 26 lb (12 kg) lighter overall weight (to 392 lb (178 kg)). The 3800 weighs only 22 lb (10.0 kg) more than the High Feature V6, despite being an all cast iron design.
Gemadore
TG Gemini 3.8
Hope this helps.
Series II
Thx Dec. 10kg is nothing to worry about :)
Decicrate
BrisVagus
VS L67
Is yours nearly finished ???
