VP 32 tooth front abs reluctor rings
Holdenut
South Australia
VP ex cop car
Can any one tell me where I can get my hands on a pair of VP 32 tooth front ABS reluctor rings? I can't believe that so many so called mechanics inadvertantly throw out the rings when doing a front brake rotors change then cant explain why the ABS fails to work.
Are there any aftermarket suppliers for these rings. Any help would be greatly appreciated.
MikeC
VQ Statesman
Tried a wreckers?
Brisbarnz
Vh sle
2nd hand is the only option. I researched this awhile ago.
Where are you located?
I have a set.
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Have you done a search?
I just did. Results. Have a read yourself. https://www.google.com.au/search?cl...luctor+rings&sourceid=opera&ie=UTF-8&oe=UTF-8
Holdenut
South Australia
VP ex cop car
I have a set.
Hi Brisbarnz, I am in SA but easy to post. How much do you want for the pair? Just checking that they are 32 tooth?
_R_J_K_
Zenki S14
Did you actually read any of those? None of them are helpful. The other thing about buying generic rings is that they are unlikely to have the same diameter as the hub they are supposed to fit on.
This is common for a heap of cars. I couldn't get ABS hubs for my Silvia, so when I tried to take the rings from my old pair and put them on the only new ones available they didn't fit as the newer set of hubs had an ever so slightly smaller diameter (and these were OE NTN replacements too).
Lex
Geelong Victoria
No l didn't read any of them.
Holdenut
South Australia
VP ex cop car
Guys I have trawled through most of sites for reluctor rings to suit my application but because they were only used on the one model they are difficult to find and to my knowledge no aftermarket ones are available.
From what I have researched this situation is common where the front disc rotors were replaced on abs models, a lot were done without swapping the rings to the new rotors, which was the case with mine!
Holdenut
South Australia
VP ex cop car
Hi Brisbarnz, I'm still interested in the abs reluctor rings if you have.
