Vp 5litre
COMMY VP 666
COMMY VP V6
COMMODORE VP
hey my mate put a vp 5litre engine into his car
as far as well all know its done 100%
new parts where easyist
but there is a problem
the oil seems to get blocked, have done 6 drains and refills, and a new oil pump
does anyone know what it could be?
thanks
COMMY VP 666
COMMY VP V6
COMMODORE VP
old oil blocking the galaries i recon
but not sure how to fix or what to do
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
is it not getting oil pressure or something
COMMY VP 666
COMMY VP V6
COMMODORE VP
yeah no oil pressure, did have put dont know, what are the best methods to get oil pressure back, already replaced oil pump
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
did you bleed the pump at all.it should suck up enough after a few seconds anyway.havnt left any bungs out of anywhere.pickup in the sump not blocked.
COMMY VP 666
COMMY VP V6
COMMODORE VP
nah didnt bleed pump, just replaced
does vp 5litres have a pressure regulator?
is it internal of the oil pump or behind/next to sender
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
The oil pump is what the oil filter attaches to. You need to cake the gears with Vaseline to get the thing to generate enough suction to get the oil out of the sump. Once it is primed you are fine. Have you checked that the sender/gauge etc is functioning correctly?
Reaper
COMMY VP 666
COMMY VP V6
COMMODORE VP
so the oil pressure regulator is part of the oil pump?
yeah the gauges are fine and senders etc
Morton
For external use only
37
Fairstar the Funship
Is it possible that your oil pickup is blocked? On rare occasions chunks of crap can fall down into it and cause issues. Pain removing the sump to check, though.
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
Reaper
Did you do this when you put the pump in, if not then thats why you have no oil pressure.
