Vp auto removel.
CPT James t
59
Hobart tas
Vn commodore
Pls help, how do u remove the auto trans if i cant get the torgue convertet bolt off.
losh1971
North Tas
VE SS Ute Shed Ornament
Why can't you get the TC unbolted?
Trevor loves holden.
vs commodore
Isn't the torque converter in side the transmission, removing the bow housing is what separates the box and motor.
losh1971
North Tas
You need to unbolt the TC from the plate and push it in before unbolting the trans same when fitting it stays in until the trans is bolted back up.
CPT James t
59
Hobart tas
Vn commodore
How do you get to the three bolts.
losh1971
North Tas
vs commodore
You buy a manual and read the instructions.
Other words you don't know.
You remove the dust cover or there should be a inspection plate at the bottom, before removing it mark with a paint pen or marker to line it back up the plate and converter, on some you remove the starter motor to gain assess.
Here is a free vs workshop it may help. https://drive.google.com/open?id=1O_KnoV949n0q46my7P2YLbmQ1Djr1SpJ
CPT James t
59
Hobart tas
Vn commodore
you cannot remove the inspection plate it goes under the back of the motor, also my trans has three plugs two white ones and the speedo is the normal for a vp berlina, or has some one switched out the trans.
