fat_head_04
- Oct 3, 2005
- 12
- 0
- 0
- Age
- 38
- Location
- south australia
- 2015 Vf Sv6
ok heres a list of mods done 2 my car found the reciepts lol
EXHAUST
3" tail pipe
3" resinator
2 1/2" hi-flow catalytic conv
SUSPENSION
rear gas shockers
front an rear sway bars
2 rear upper control arms
2 rear lower control arms
2 front radius rod bushes
2 front radius rear bushes
2 lowered front king springs
2 lowered rear king springs
2 nolathane adjustable strut bearing plates
BRAKES
2 vt front disc rotors - GMH
2 vt front calipers - GMH
2 front adapter hubs
1 vs brake booster
1 vt master cylinder
ENGINE
Hone cylinder bores - Std bore
linish crankshaft - 10/10
resize conrods
reconditioned heads
1 crane cam
1 lifter set - Anti pumpups
1 ACL race gasket set
1 piston ring set - ACL
1 Main bearing set - ACL
1 rob bearing set - ACL
1 oil pump - GMH
1 injector set
1 water pump - GMB
1 genie extractor set with crossover pipe
1 crow valve spring set with collets and retainers
TRANS AND DIFF
1 3.45:1 gear set - new BTR
1 Reconditioned LSD diff
2 axle bearings
full transmission rebuild
1 80ltr fuel tank
1 fuel pump
INTERIOR
full vs/ss trim
jvc head unit
kenwood 7'10 in the back
2 12" subs powered by 1000 watt amp
thats about all for now. i might get sum diff mags in the future but ill stick with these for now i spose. wat do u all think????? leave me sum feedback with any comments
EXHAUST
3" tail pipe
3" resinator
SUSPENSION
rear gas shockers
BRAKES
1 vs brake booster
ENGINE
resize conrods
reconditioned heads
1 crane cam
1 oil pump - GMH
1 injector set
1 water pump - GMB
TRANS AND DIFF
2 axle bearings
1 80ltr fuel tank
1 fuel pump
INTERIOR
full vs/ss trim
jvc head unit
