VP Bumper Bracket
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Hardstylin, Dec 8, 2008.
  1. Hardstylin
    Hardstylin Banned
    Melbourne, Victoria
    VP Calais
    The left side of my front bumper on my VP is hanging down and is unroadworthy, what exactly needs replacing?
    I'm aware it's some sort of bracket, but how big is it and is it something I can pick up cheap?
  2. Morton
    Morton For external use only
    Fairstar the Funship
    It's a plastic bracket with two guides, top and bottom, and it runs into. It's possible that it's simply fallen off the guides, and that they're not completely broken.
    Four bolts (18mm?) down the front of the car will remove the reo-bar, and you'll be able to slide the front bumper off and have a look :)
  3. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    Or theres 5 bolts holding the front bar to the reo, if thats easier. Reo is pretty heavy, more so if your not expecting it to fall on your guts.:p
  4. Hardstylin
    Hardstylin Banned
    Melbourne, Victoria
    VP Calais
    Alright, I've undone the 5 bolts, the bar is pretty loose, but I cannot get the right side off the side bracket.
    Any suggestions?
  5. STEALTHY™
    It is designed to slide forward. Be careful not to pull too fast, as you'll snap the plastic mounts off.
    When you slide it, keep it level, and you should be alright.
  6. Hardstylin
    Hardstylin Banned
    Melbourne, Victoria
    VP Calais
    Great, got it, I would have snapped it otherwise.
    Thank you very much
  7. Hardstylin
    Hardstylin Banned
    Melbourne, Victoria
    VP Calais
    Hmm, I typed the number in Rare Spares and it come up as RH, although it says LH on it.
  8. wildss
    wildss Member
    s.e melb
    vnss
    pretty sure theyre reversable
  9. Hardstylin
    Hardstylin Banned
    Melbourne, Victoria
    VP Calais
    Unfortunately, they are not.
  10. wildss
    wildss Member
    s.e melb
    vnss
    must be the rears then
